- Jan 23, 2016
- Mississippi
- Jesse
- V1500 Jimmy
This has really got me worried so tell me what you guys think. I've had essentially what you could call the lower rear cap off the Jimmy for some time now with cleaning up, fuel tank/sender/pump replacement, and rear bumper and beacketry replacement. Well, I put a new set of brackets on, and I've really got a visible problem concerning the outer ones. It looks like sway type frame damage, but I don't know. The drop hitch was also in a huge bind, and it will not realign for proper reinstallation. Everything lines up well in the front, or so it seems. I've looked for additional signs in the rear. Shocks binding, weird body mounts, ****** repairs, etc., but I don't see any of those things. I put my fists against the tires to make sure both wheels were equidistant from the fender edges, and three fists lined up while the fourth was about a half inch off in the wrong direction from the apparent misalignment. I don't even know if that was a conclusive test. I put a straightedge on the inner rear bumper brackets, and they're pretty close, but looking in the background I can see that their misalignment is pretty much parallel with that of the drop hitch. If there is damage, I'm hoping it exists only beyond the rear axle. If my memory serves me correctly, the old rear tires were worn evenly unlike the front ones that had very unevenly worn tread. Here are some pictures. Any ideas, suggestions, or comforting words would be vastly appreciated because I'm freaking the f out right now.
Passenger Side
Driver Side
Aluminum bumper filler is in overall decent shape. Maybe slightly bent, but drop hitch appears askew independently.
Passenger Side
Driver Side
