Honky Kong jr
Super Sarcastic Man
- Jun 14, 2016
- Denver,PA
- J-me
- V10
- Lil BB 407
I have an 89 K5 frame you can have. You come get itFrame
That's how I did my K5 bumper on my truck. Got the bumper whet o wanted it and built inward. Because at the end of the day all your gonna see is how well the bumper matches up with the body. No need to over think it. LolI see the outer bracket has a slotted hole where it bolts to the bumper. Are you sure that bracket isn't bent and couldn't be pulled up to the bumper? I wouldn't be too concerned with getting the brackets all lined up before installing the bumper. It is my worthless opinion that you should loosely assemble the bumper and all the brackets ant try to get the bumper as square to the body as you can with the inner brackets. Then see if the outer brackets will pull up to it. From what was said about the hitch, how bent it is and the fact it was bolted to the truck it sounds like pulling things up to position is how it was put back together before. Apparently well enough that you didn't notice until you took it apart. For the record both ends of my 03 Burb are crunched and in order to get it to look right I did a lot of pushing and pulling of the bumpers and the hitch.
