Im stumpped
Ahhh Fugg !!! Yep, that'll do it !!!
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ya so I took it for a test drive and she drives so nice I'll be taking it to smog tomorrow
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Also thank you all for the help on this truck pointing me in a better direction and Jim I owe you some beer man
animal
Lee
c10 silverado
350ish
Glad you got it running good.
Great work Jim!!!:wave:
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Gawwwdddd daaaaamn! That **** was done!
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ya buddy it sure was just enough for it to run at idle but fall on its face passed that no more rich running no check engine lights smooth as a baby's ass and tons of getty up and go
Jims86
Patterson,Ca
5.7 TBI
Ecm was commanding injectors at full duty cycle to make up for the loss in pressure, then when it realized it was rich, it backed it off....thats why the surge.
Also explains why no CEL light too. Once the Temp Sensor was replaced, then no reason for a code.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Dude I'm just happy its fixed and finished :upyours::roflbow::gr_guns:
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Well it failed smog and blew up the front pump seal while driving it back home from smog the trucks new name is Murphy law
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Here is the test results Jim and any advice you can give me on where to start fixing would be great
Jims86
Patterson,Ca
5.7 TBI
Hmmmm..... Ok, what was the deal with the air cleaner? just the heat riser hose?
Fuel leaks
As far as the cat reading, that may be a result of weeks of trying to diagnose, without a good daybor so of driving to clean it out, and I do understand that was not possible to do, since you just fixed it yesterday.
the first thing obviousely, is the trans issue.
then I would go through everything that didnt pass on that list, starting with setting timing back to 0*
Maybe the fuel cap from the 88 is in better shape?
Dump a gallon of laquer thinner in the tank, and run that bitch at 1500 rpm for about 1/2 hour. Will he do a free re test?
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Timing was at zero when testing I have the other transmission that I will be putting in on my next day off from work thankfully I have that transmission still and I'll go through everything I can when I can
burnt
