cudajim
- Apr 29, 2022
- Grass Valley, CA
- Jim
- K10
I got roped in to fixing a customers K10 with electrical issues. The first thing I noticed was that the key was very hard to turn and the previous hack installed an aftermarket push button switch for the start function. The short story is that they installed the ignition switch (on the column) upside down and ran the rod underneath it. It sorta worked but wasn't right. Anyhow, I bought a new switch, installed it the right way and it's all working but now I cannot get the rod to stay in place at the switch. Is there a clip or something else that holds it in? I'm a Mopar guy so this is new to me.
As a side note, it was also not charging properly. The previous hack ran a nice fat cable from battery negative to the chassis. No cable to the engine at all so he had a floating ground and the alternator didn't know what to do. I ran another hefty cable to the block and solved several problems. I now have 14.2 volts at the battery.
