suburble
- Sep 23, 2013
- Arizona
- Josh
- Suburban C20
Hey, all. Finished replacing a bunch of tune-up parts on my '86 C20 Suburban but I'm still having problems. It's a 454 with HEI.
Here's the history:
It starting acting like it was missing a cylinder last Friday. When I tried to start it last Saturday it fired over and idled for a few seconds and then died. After that, no spark at all.
I pulled the cap and wires (pic below) and the rotor button was GONE, and some of the wires toasted to the point of crumbling.
I replaced the plugs, wires, cap, rotor, coil, Ignition module, and the Radio Noise suppressor part that plugs onto it.
It fired up and ran great for about a mile, then cut out completely. Once again, no spark. There was one more strange symptom- the windshield wiper ran intermittently for the first few minutes after I first started it up (this has not happened before).
The plug wires, rotor, contact button, etc. all looked fine. I went to the parts store and got ANOTHER coil, ignition module, and Radio Noise thingy under warranty. Still no dice. Parts all looked fine, no rattling in the coil or modules, no signs of arcing.
I spent about 4 hours playing mix-and match with various new parts and checking connections. I could not get it to fire once. It was turning over just fine, just no spark.
I had it towed home, tomorrow I will check if it's getting 12v at the coil.
The only 2 things I can think of are:
-It might have a short in the wiring going from the ignition switch to the coil, or a bad ignition switch
-The distributor pickup mounted under the advance weights might have somehow gone bad
Here's my questions:
Assuming it has 12v at the coil, is there anything else in the system I could check besides the distributor pickup?
If it does not have 12v at the coil, am I safe bypassing the ignition switch wiring by running a wire to the coil directly from the battery, for test purposes?
Should there be fuse, breaker, or fusible link anywhere in the ignition wiring?
Add'l information: All parts were BWD from O'reilly Auto Parts.
Pics are from the old parts I took off. None of the new parts look bad.
Here's the history:
