How to Weld
Carb'ed Vortec 350
Dammit honky you beat me to it...
Carb'ed Vortec 350
That commercial cracks me up every time I see it...
3504boltmain
Virginia
Trent
C30
5.7l
Nuh uh....if you have a battery you have a crude DC welder.
Don't tell people that! *Disclaimer: not my fault if you don't disconnect it from the truck first.* There, phew. I wonder how much damage it would cause if you didn't.
Edit: Better yet
Instructions:
Connect leads to positive and negative terminals (it doesn't matter which one goes where).
Start truck
Block throttle open to 3k rpm and leave it there
Connect ground strap to work piece
Insert stick into stinger
Run Bead
(The truck might bog a little this is normal. If you hear popping sounds from what you are welding, you are welding to fast, slow the puddle travel speed).
If you hear an explosion, you have finished your weld.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
For one don’t tell me what to do. And 2 anytime you weld on anything you disconnect the battery. And 3 if some one is gonna do that they are a seasoned individual, not a novice that doesn’t have a clue.
3504boltmain
Virginia
Trent
C30
5.7l
Check edit above.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Edit: Better yet
Instructions:
Start truck
Run Bead
Or the alternator blew up....
Affende
ColoRADo
Affende
83 and 84
C1500 and K3500 3+3
250 and 454
I’m just being me. I’m certified 1” overhead. And have been for 16 + years I build overhead cranes.
uphill, downhill, side to side. No crack too tight no gap too wide! If i can step across it, i can weld it up. From a broken heart to the crack of dawn ... i have a rod for every job!
hatzie
k20
I’m jealous. I bought a Hobart mig years ago but I hav never learned how to use it. I doubt it’s even set up properly. I need a teacher/mentor but I’m getting pretty old to just be starting to learn.
It's a skill like any other. You'll need to practice. Doesn't matter how old you are just how interested you are in learning.
Community colleges used to have welding classes.
Is that like Muff divers 69, No muff to tuff, we dive at 5
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I'm learning to TIG right now.
Our tool room has a big old Miller I've been practicing on. I've only ever MIG welded, but I'm finding it pretty easy. Of course our tool makers all have lots of experience to help me, but I've spent about three hours on it this week and I can make functional welds.
The main problem I'm having is regulating the heat with the foot pedal. I'm just not used to it and forget it's there.
ajd89
Central Michigan
andrew
We dont even use a foot pedal on our tigs at work. Just has a high Frequency start and your off! Lol
GorillaHumper
