How to "Un-Lift" my suburban
Slooptin
Denver
Vance
k30
Hey guys/gals, after a few years with my big ass suburban, I'd like to tone it down as it sees more daily use than trail use most months, plus my wife has started driving it more and while she loves it, she doesn't love being 5' tall and having to hop up into such a tall truck every time. It currently has the following setup:
Rear:
- 14 bolt 8 lug swap
- ORD shackle flip with unknown springs (fronts are 6" lift)
Front:
- 10 bolt 8 lug
- crossover steering
- sway bar disconnects
- 6" springs from ORD
Skyjacker shocks all around
Extended SS Braided brake lines
37" tires
I'm thinking I'll at least need new springs/shocks and downgrade to 35s or 33s. I can probably leave the brake lines as they aren't hurting anything. I'll possibly need new driveshafts if I go too low, but I can either source used ones or have a driveshaft shop shorten mine. I guess I'm really looking for recs on new shocks/springs or a direction as this isn't typically the route people go. I'd like to get down to the 2-4" lift range and add smaller tires
EvilGenius
Metro Detroit
Darien
Might be able to set up a swap for stock suspension parts with someone looking for a lift. ORD stuff is nice and should be desirable.
I have 4 in lift all spring from tuff country and like it a lot. Kinda wishing I had gone with a 2 inch lift, but still happy with what I have.
Not sure how crossover steering works with lower lifts though.
What engine/trans/gear combo are you running? If you are geared properly for 37's, you may not want to go significantly smaller with the tires.
Zelph
Nevada
Since your issue the wife being short and the tall truck an alternative to changing out the suspension may be to add some retractable steps.
Back when our '88 Suburban was on 33's and the 4" lift, my wife drove it most every day. She's short, but she could get in ok. When she would take her mother somewhere, we had a little plastic step stool with a rope tied to it so her mother could get in and out.
Slooptin
Denver
Vance
k30
350/700r4/4.10s so I'm probably geared too high as it is. I keep it out of OD unless I'm on the highway
PO welded step bars/sliders to the frame, plus I'm not really a fan of these as I've seen people have issues with them not working well even on newer trucks
gmbellew
Kansas city
glen
suburban 1500
350/700r4/4.10 would be pretty good with 32-33in tires. I have the same in my burb but with 3.73. I wouldn't mind a little more gearing at times when its windy on the highway, or another 50hp...whichever is easier
Auburn, Washington
First thought is find someone to trade suspensions with. Probably enough light duty Square 4x4s in the Denver area to find a taker.
Barring that, fire up the Mastercard and the internet. Easy peasy.
If you want rides like a stagecoach wagon get Rough Country front springs. If you don’t buy anything else. Ride and quality typically commensurate with price. Skyjacker soft rides are a good compromise between ride and $.
Shocks? Again $ = quality how high is you budget and cc limit. Skyjacker is good quality gas shocks for not allot of money. Bilsteins for the mid range $ vs performance and they’ll probably last 20 years. Or double down with the AMEX too and order ya some remote reservoir something or others.
Slooptin
Denver
Vance
k30
If I went down to a 4" lift, would my shocks still have enough travel to reuse or would I need a whole new set? Not opposed to buying new ones, but mine were done about 2 years ago so if I can keep them, that would help.
But yeah, I'm looking at the skyjacker springs for the front and just stock replacements for the rear which should get me down to 4" lift. I'll probably wait until I can find a decent deal on some 33s or 35s
Sounds like a great candidate for a 4 inch lift and 33's.
Auburn, Washington
Just gotta measure.
Or use a chart like skyjacker has and then measure.
No one here knows what you have for length and what fits. This isn’t one size fits all and you have a franken truck. Which means just measure.
And I’d wait until after I did springs and broke them in a bit unless you order guaranteed to fit so returning isn’t an issue.
Just gotta measure.
Exactly. There's way too many variables between shock manufacturers, spring rates, truck weights, etc. Your current shocks might work, it will just depend.
Aardvark1024
