How To Refurbish Your Dashpad
950931
Riverside CA
Adan
Going to try this on my dash pad.
Camar068
Kentucky
10 yrs Air Force
still working on mine here and there. Trying to decide if I want to put some angled up speakers in the speaker holes or just fill them in. Be a good spot for tweeters if anything.
Got plenty of time, I'll research good speaker dimensions/specs to see if anything good can be made to fit. I did think about putting a small display in the center speaker hole for a back up camera. Be nice if it was flip up.....a permanent display might invite theft.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I like what's going on here.
Im looking to redo my dash pad in my suburban.
I just need to find a way to match the color in my suburban.
Camar068
Kentucky
10 yrs Air Force
So I blocked off a few edge cracks as well as the transition from the cluster. Few more minor spots (not including the transition lol) and those will be taken care of. The transition will probably take more elbow grease. Because it's got a corner I'll have to eventually start hand sanding.
Transition:
Defrost cracks:
Crack above the cluster:
Above vents:
Camar068
Kentucky
10 yrs Air Force
Just to give you guys an idea how long this takes:
10 minutes - Clean area with acetone, mix epoxy, and spread/pour
10 minutes - if you have to dam up with putty/play-doh
20 Minutes - sand (orbital sander) all the spots in the previous post pictures
I do give it 24 hours to dry, so it's best to do as much as you can in one cycle.
Ran across this guy, does a awesome job. Probably a little heavy after, but who cares it sits in one spot.
OldBlueDually
Minnesota
Justin
1976 GMC
C30
455 Olds
Good thread!!!! I have to do the same to mine also.....don't want to spend $400 on a new one...yet...
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Going to do that to my dash.
Usmczo6
New york
Alan
V30
That's for the great thread, my dash came out great, after primer and vinal paint it looked a little flashy , I hit it with this textured paint it came out amazing, I'll snap another shot installed once I get home
Usmczo6
New york
Alan
V30
2 more pics, they didn't upload, foam and fiber glass filler before the bondo, it looks great thanks guys, I'm gonna dril holes in sheet metal, and paint for the the speaker and center cover
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
My attempt came out crappy. The cracks in mine were just to wide and many in my opinion. I'm going with the plastic cover.
Usmczo6
New york
Alan
V30
I would try to cover the entire thing with the Bondo fiberglass product, a 6-in drywall knife It's your Best shot, the textured paint I used hides a lot mine was nowhere near perfect before primer
I just picked up the November issue of Hot Rod magazine, there's an article in it about repairing the plastic dash of a GMT400. They ended up flocking the dash, which it think is a great idea and an alternative to using textured paint.
OldFatBald
Northern California
C30
This is my first attempt at a Squarebody dash repair.
The materials that I used were:
Canned spray foam
Hardware store mesh
TotalBoat’s FlexEpox (flexible epoxy) after seeing Camar068’s post
Upol 7061 Flexible High Density Body Filler (Flexible Bumper Filler)
Upol Raptor liner
I pulled this dash out of a Suburban parts rig that I bought a while back. Pretty typical cracked dash, not as bad as some that I have seen.
Since this dash is going into a C30 dually that I am going to sell (I really don’t need two of them) I decided just to do away with the speaker cut outs. I also V-grooved out the various cracks
bryanedge117
