- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
Don’t forget, no idea how it was used before you got it. I’m presuming your plow truck hasn’t seen enough miles to put appreciable tread wear on a new tire in the last 4 years.I did some research. old tires, lots of low speed turning, a LOT of weight on front end, and a wide tread patch(more resistance in turns) with a moderate sidewall(some flexing) are likely contributing. And sitting rather than getting used
Bottom line schitt happens. They’re tires. I even had one slip a belt on my truck, on the front couple years ago. Felt like alignment was off a bit. Swapped to rear, forgot about it and rotated back to the front last year and it was fine.
Talk about mysteries.
