How low is your transfer case?
firebane
Calgary, AB
Curtis
Now that I'm putting a lift on my truck I've noticed how low the transfer case hangs. I'm curious how low others hang and if there is a way you could perhaps raise it up to give more ground clearance.
Also do different transfer cases hang lower than others? Like does a 203 sit lower than a 205 or a 208?
This is a picture of my truck with the 203 and I'd like to think I could lift it up..
MadOgre
NA
NA
NA
NA
NA
That's not bad at all! You can barely see it lol What tranny? Im guessing a TH400 ? My 4l60/208 hangs down about 5 or 6 inches and Im gonna lower it another 1" as well. Important thing is to have the skid plate in place. so any rubs are rubbing the cross member not the case.
How much off roading are you seriously gonna do? I gave up wheeling cause I got sick of having to fix it after every wheeling adventure. And I didn't have enough money to build a serious off road rig. Now I have the money but no desire to go off road lol
firebane
Calgary, AB
Curtis
TH350 under it. Yeah it has the skid plate in place. 6" low? Wow.
MadOgre
NA
NA
NA
NA
NA
Ya, Besides when you get a real 4" lift it will sit a lot higher then she is now. I would put a 1" spacer in the back of some sort when you get the front springs sorted out.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
With 6" lift I had to lower my t-case for better rear driveshaft angle, yours looks fine. :cheers:
firebane
Calgary, AB
Curtis
A zero rate will in the works to put the axle back where it belongs.
MadOgre
NA
NA
NA
NA
NA
Ya that will work. The rear wheel well, is exactly 1" lower to the wheel then the front. So if you put an extra 1" of lift in the back it makes the wheel openings look the same and jacks the whole back of the truck up that 1" to give it a little bit better overall stance.
Don5
West Virginia
Don
k15
The T case is the one thing I never worry about since I have a skid plate under it.
firebane
Calgary, AB
Curtis
Wasn't worried about hitting it. Just wanted to make sure this was a normal thing :popcorn:
Don5
West Virginia
Don
k15
I understand. Just covering the bases. I can't wait to see some pics of it lifted when it is done.:)
zapattack
