how fast is your power window?
Because I am bored and slightly geeky I timed them ha-ha
Engines running
1987 GMC 6 to 7 seconds going down and the same time going down
2001 Tacoma 2 to 3 seconds going down and the same time going down
Can the relay kit improve on 7 seconds or is that for really slow windows?
That's about how mine were, 6-8sec to go up or down. It's a crap shoot whether or not the relay kit will work or not. Like I said above, it helped my pass side but not the driver's. My theory is the driver's motor was on it's way out anyway.
shortshift
Seattle
77 gmc had slow power windows.. Replaced worn out regulators and that totaly solved my problems. The old ones were not only worn but the rollers were trash. Also you can run a direct 12 V from the battery to the motor and see if you have a wiring problem or switch problem. Good luck
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I did the relay and express down modification on my 81 a few years ago. The windows are pretty fast now. Not new car fast, but definitely better than they were stock.
PartsMan79
Enid Oklahoma
Josh
c1500
I had my driver window actuator out, thinking it was bad, the other day.
It runs much faster after cleaning and lubing.
I need to do the passenger side now.
idahovette
Weiser Idaho
Perry
K20-K10
Did the relay thing on Brody's(G-son) 79 K10 on just the driver side. The passenger side worked great so we didn't do it. Did NOT help the driver side one bit. BUT, it allowed me to replace the gears on the motor, they were toast. SO, at least it goes up and down now.
Manual windows never fail. Even better, it leaves more room in the doors for speakers!
Well the regulators can still fail/wear but they are easy to replace. However, I would like to point out that square bodies have very fast crank windows. the fords of the time did too. The GMt 400, im not sure. but the gmt 800 crank Windows SUCK they take a lot of cranking and the crank mechanism is so flimsy and cheap.
mibars
Nadarzyn, Poland
Michal
Suburban V1500
Slower than in modern cars, but not terribly slow. Driver side window is faster, passenger window is slower, will get a relay mod soon.
All windows got noticeably faster after proper greasing of mechanism.
My rear windows were terribly slow and they got a relay mod that solved the issue.
mibars
Nadarzyn, Poland
Michal
Suburban V1500
With the power windows so slow in our trucks a solution may be to use a step up converter in a circuit for power windows. Having a converter by the motor that takes whatever is reaching it and outputting a steady 14 - 15 V would make a window regulator substantially faster.
I used a lab power supply to power window regulator to determine if the regulator itself is not an issue and about 14 volts was enough to get them to work like in a modern car.
oplinger
Nashville, TN
Justin
r10
A, no way I'd go from red to black in a white truck. A white vehicle with a red gut is just sexy IMO. B, if you do switch, NuRelics really is the way to go. They're not cheap but install is a breeze and they work great.
Ughhhh red has NEVER been appealing to me. This truck was originally a red on red truck, and if it was still a red exterior when I saw it, there is no way I would have even entertained the idea of buying it. lol.
But if I do switch to power windows I def wouldn't skimp on the parts. Pay once for the good stuff rather than pay for the cheaper stuff and then wish I paid for the good stuff anyways.
Hottshot0069
Schertz, Texas
Doug
Here's mine in my 87. I did lube the tracks when I had the door panel off.
Are you still using the OEM motors? What type of lube did you use and where all did you apply it, channels and the the motor? My passengers side is super slow and my drivers side will not roll all the up on its on.
Haha Yeah it's not everyone's cup of tea. I don't care for the red on red, that's too much. But white on red is gorgeous.
WFarm
Central Virginia
K5 Blazer
I can’t say if the motor is OEM or not. i wasn’t having any problems with them so didn’t look, just took the opportunity to grease the tracks since door panels were off. I used a white lithium grease.
87gmcburb
Don
GMC Sierra Classic Suburban
This my 3rd burb with power windows and no matter how much I lube the gears, channels etc... they are slow. I have also installed all new weather-stripping which doesn't help much either. They are notoriously slow because the way they are wired up with out relays like modern cars.
Having said all that, sometimes they are excruciatingly slow like the front passenger one on my present 87 burb. I have a new motor for this one. This will get it back to OEM slow. :)
rodfarm
