How are factory Suburban luggage racks mounted?
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
Guys, don't laugh but I think I'm going to install a factory luggage rack from a '90 on my '91 that has never had one before. How are they mounted? I have all the pieces that came off the '90 but I neglected to take pics when I was removing it and now I don't remember. I probably have the mounting screws or bolts, but they're mixed in with a lot of the others I took from the '90. Are they sheet metal type of screws or through-bolts that would require removal of the headliner? The rack is black and it has only four feet, not six.
The reason for the rack: just like the looks of the factory rack. I would only use it for light, small loads if at all. My '91 has brackets for a cross bar style rack that someone added along the way. If I ever want to carry a canoe up there or similar I'll use thule or yakima style bars to do it.
I'm also going to mount the overhead spoiler from the '90 on the '91 at the same time. Same style of mounting screws for that?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Haven't seen one with just four mounting feet instead of six. What's the length of it? Are you sure it's oem?
The factory stainless rack is 6' long on six mounting feet. The two middle feet are mounted with pan head sheet metal screws 1/2" long. The front and rear feet are a combination of screw types, the screws closer to the middle feet are the same pan head sheet metal screws, but the screws used in the most forward and most rearward mounting holes are 8-32 x 3/4" machine screws. Not sure what they tie into with the extra length, maybe someone that's had their headliner out can chime in.
Couple of pics of the factory rack which I used as a mounting platform for an aftermarket basket.
glockholiday
Jeff
V10 Suburban 1/2 ton 4x4
Mine were 1/4x20 screws that look like these with a tapered shoulder. There are female threaded inserts mounted in my roof.
Daveo91Burb
Vancouver, WA
Dave
You're right, it's got six feet, not four. Was mixing the feet up with the fact that it has just two cross bars not three. So I think I'll do some threaded inserts for the four outside screws and then sheet metal screws for the remainder, sound ok? I have four plastic gasket things, guess the middle feet don't need them?
Now here's a question -- are these little pieces part of the rack? I swear I remember them being associated. But I don't see what purpose they'd serve. Problem is I only have five, not six.
That's how my '88 rack is mounted. There are nutserts in the roof, btw. The '89-'91 Burbs seem to have all got a different style rack than the previous years.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I think you would be ok with sheet metal screws all the way around. It's not like you're going to be tying down a piano or anything like that. Twelve screws into the roof and it's not going anywhere.
I have an extra set of pads for the middle feet. PM your addy if you want 'em.
Those look a lot like the mounting inserts for the four 64" stainless rails that mount directly to the roof which are used to keep cargo off of the paint.
Looks like you don't have the rails, but if you do there are 7 inserts per rail so you're missing 23. The ones you have are a little different than mine but if they measure 3/4" wide by 1.5" long that's what they are. My rails were all coming loose so I took 'em off when I had the truck painted and never put them back on.
Daveo91Burb
Vancouver, WA
Dave
Thanks for all the info. Good stuff, especially that sheet metal screws should do the trick. No, I don't have those rails and I don't remember my parts rig having them at all. Hmmm. I'll do some research. And let me hint around for the middle feet pads before I have you send your extras. I might be able to find them. Thanks to all for the input.
cahillasher76
