Homemade car trailers
No, I can't upload pics period. When I hit the upload a file button it turns grey for a second but does nothing. I opened another thread about this, but no responses and tmobile tech is worthless.Anyways if anyone hays any ideas please let me know.
Popup blocker? In app or website? Browser? I would venture you have a popup blocker or adblocker or permissions for your app dont work. if on an Idevice, try chrome browser. If on a android, try another popular browser like firefox or chrome or safari from the app store.
I'm sorry I should have come back to this sooner.I opened a seperate thread specifically to address the no pics issue. Vbb199 nailed it. I had chrome,but had been opening the site from my email,opened in chrome, problem solved.Looks like aurora girl would have solved it also. Anyway thanks everyone. Merry Christmas. I'm happy I can post pics now. Gotta go, need to take pics of my son's cat for you guys.
Has anyone built something like this? Anyone got an idea what size angle those rails are, looks like 2x2 but what weight? Also looks like 1 and 3/4s angle going crossways every 4 feet
Does anyone have access to a 4 post lift? Can I talk you out of some bottom side ramp pics , and basic thickness. That's basically what I need to build is 2 decks like on a 4 post.
Thanks.
Thanks.
I don't think those two uses are comparable? Supporting a stationary vehicle is going to be easier than supporting one that's bouncing down the road.
Those angle runners on the above picture look to be 2.5" and probably 5/16" or even 3/8" thick. The required beef of the materials is going to depend heavily on the other structures of the trailer. Are the runners going to act as the trailer frame, or will there be a frame below the runners?
Personally, I'd like to see a heavy 3" or 4" channel frame (and crossmembers) with those thick 2.5" angles being used as the runners.
What deck length and weight rating were you going for again?
Well I went back and read again. Your primary use will be stationary. But my opinion is still the same. It will have the ability to move around and see additional stress. Be safe and go heavy.
Bucket I think your right about that angle being bigger than I thought at first I was already planning on a 4x4 square tubing perimeter frame with removable angle iron crossmembers every 4feet. Didn't original want to use wood decking but those looked so simple.
I want to build something like this, with crossmembers that can unbolt and a single axle.I have a 16 ft flatbed and a car dolly so this things use will be a service tool.I suppose if I ever wanted to use it on the road I could add a second axle later.I guess I should build it as a dual axle and only put one on for now, but prebuild it for both. Damnit I think it's all figured out.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Put the trailer on those 36s that are on top of it and turn your truck into a DONK!
Are those wheels capable of turning without tearing up the fenders? Just for show? Not opposed to big wheels on vehicles but they still need to be drivable.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I have no idea. I think they’re atrocious. I think they’re a bit more narrow than you’d expect for the height, but I still doubt they’re going full lock to lock.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Yeah the wheels are a little big and the sidewall is sort of nonexistent. Seen worse though, like tires cut in half and just the tread screwed onto the rim to act like a tire because they're so big and they needed two tires to make one. Sidewall gone..:eek:
Ran across this today.Not for sale but I took measurements. The angle iron on this isn't even as thick as my flat bed so I'm just going to modify it by pulling out the center boards and adding 2 pieces of angle for the runners.. He can use this as a flat bed or an open center car trailer. Anyone needs any measurements.I got them.
Sauc3r
Mount Vernon, IN
R30
7.4L 454
please?! Also thus may be a stupid question. Where would be the best place to get metal... I have welder, and can actually weld, just short on material lol.
IDK in Kansas there are several places I can just drive too. I'd Google steel distributors in your area.
Sauc3r
Mount Vernon, IN
R30
7.4L 454
Alrighty sounds like a winner. Too bad my area is a definite no fun zone for stuff like that lol.
southbaymiller
