Thought I would pick this apart a bit. Even tho people are quick to blame the carb, no matter what the brand, more often than not, it is other issues. The main culprit is usually with the timing. Of course we know this is a used carb that apparently set for awhile with fuel left in it and most likely uncovered by the crud in it. Something as simple as changing plug wires can creat issues. Yeah, more times than I want to admit, I am guilty of crossing a wire thru the years. One thing I didn’t mention in the break down is how far out the idle adjustment screw looks on the passenger side. May be an illusion. Would like to see you get this figured out. Carbs are really very simple if you think about it. Far from a carb guru, but I’ve messed with them for many years and could figure things out eventually. Just hard to do long distance without knowing the full story, standing next to it while listening, and feeling it while driving. Hard enough typing all this with two fingers
Got tired of messing with it so I took it to a shop. Everything is set fine - timing, acc pump, etc.
After all the messing with the carb, they set everything back to Holley specs? They set the idle mixture screws using a vacuum gauge? Verified floats were set correctly. What is the timing set at?
Truck starts and runs great but you still have to ease into it at stop lights or it will fall on its face.
Most always a misadjusted accelerator pump arm. But they say it’s alright? Right? Then a vacuum leak somewhere. Hoses may “look” good, but never assume they are.
Idle is also still high and adjusted as low as it will go. I could spray carb cleaner on the back of the carb and get a very very slight reaction in the idle.
Pretty says you have a vacuum leak if spraying raises idle. That’s would be why the idle won’t adjust down. Or timing is set too high.
They messed with it today and said the vac port on the Holley is not metered - so its at full advance all the time.
Not sure they’re saying here. Anything above the throttle plate is ported vacuum (only pulls vacuum once the blades start opening up). Usually used on smog checked engines. Anything under the plate is manifold vacuum (pulls all the time). Full time usually is best for improved idle.
I marked in the pic the only 2 places it could go. Holley per their pics, says the upper side is where the vac adv goes.
Probably one of the most heated debates on the web. Some claim top port on block is the best. Some the lower port. No 2 engines are the same so different strokes for different folks. Try both while idling. I’m thinking the lower will give the best idle.
