High temps
Sandcastle89
Florida
Jon
350 4BBL 5.7
Howdy,
Wanted to get some input from everyone - would a failing brake proportioning valve cause the truck to run hotter? The temperature isn't consistent. It never gets into the danger zone.
I also want to remove the trailer brake booster that is connected to master cylinder. The temp on my last drive was not as high as the picture below.
We recently put a 160 thermostat in, made sure it has plenty of coolant, and ensured the water pump is doing water pump things.
The timing is where it should be as well.
This is a picture from the most recent drive (Saturday)
fast 99
Spokane, Washington
Really, factory gauges are indicators. Unless brakes are dragging causing the motor to work harder can't see a connection.
If you want to know the actual temperature need to install a mechanical gauge. Also depends on where the sender is installed. If near the stat will be about 15-20 degrees cooler than if in the head.
Temperature reading in the pictures wouldn't alarm me at all.
Sandcastle89
Florida
Jon
350 4BBL 5.7
I'm glad to hear these readings don't make cause for concern. I am going to keep on driving. Thank you.
Russo
