13matsc
- Apr 9, 2024
- Norway
- Mats
- C2500
Hi guys,
My truck has had a leak from the oil pan gasket for some years now. Finally dropped the pan and installed a new fel-pro 1-piece gasket. At the same time i replaced the rear main seal and also the oil pump and pickup because why not when the pan was down. Put new 10-30 oil in, same type as always, but now the oil pressure is way higher than before.
The new oil pump is not the high pressure kind, and i replaced the oil pressure sending unit two years ago when it was acting up.
Now im 60 psi when high idle on cold start. Drops to about 45 when engine is warm and normal idle. About 55 psi when running 50-55 mph.
Before it would be about 35-40 when cold and 25-30 when idle on warm engine.
Should i be worried about a faulty new pump?
