BRetty
- Jul 16, 2020
- Los Angeles
- Franklin
- c10
All,
My 350 SBC (TH350C trans, just rebuilt 2 months ago) has a steady RPM-based tick/click that starts after about 30 seconds of startup/idle. Putting it in gear makes it worse, applying throttle it becomes a very loud horrible clank-clank -- but the sound immediately backs off when I coast in gear.
It sounds like fan blades clipping a hard line, in fact a similar staggered 5-blade rhythm, but I checked and nothing is obviously interfering.
I has the rear end off the ground on stands and ran it in gear, didn't notice any odd noises then.
Started it just now after 2hrs and engine sounds fine, revs up and down in Park with no problem
On Sunday I changed my spark plugs, and after fixing a couple mistakes -- I had switched wires 6 and 8, found that within 100 yards of driving -- then #1 was loose, connected it securely and stumble vanished -- I drove home all was good
Monday driving into work, I started to feel the rattle and lose power, so I pulled off (*) one plug wire was burnt through, I replaced it. I WAS VERY LOW ON OIL, ADDED 2 QUARTS. From the jug I had bought meaning to change oil....
when changing spark p,ugs, I had to jump in engine and thought maybe I had stomped something loose in the fender wells....
From under the truck, it sure feels like the flexplate or oil pan is source of rattle, not back by the driveshaft/diff. U-joints look fine. I know I need to replace diff ring/pinion soon.
My crank pulley looks pretty eccentric, I need to take off belts and see if it's pulley or balancer or what.
I checked vac gauge, my vac is low (~14in, has been 16-ish) but there's no dip or stumble lime a broken rod or lifter. I have not removed valve covers to check yet since I think it's dkwn below.
* Any thoughts on what to check next would be appreciated. *
I'm going to trans shop to have them re-check my flexplate and torque converter. After that I'm taking it to the local Armenians with their lift to get a good look.
Rattled,
BRetty
* -- Just a PSA, times have changed. Stopping right in front of a High School at 7am on Monday, popping the hood on your 50-yo truck and staying there for 30 minutes is NOT COOL. Apparently some Seniorita Manicure called the cops about a "suspicious vehicle". Called from her leased SUV no doubt. Fortunately one of the cops had (or used to have - I was talking to his shoes) a 70's chevelle or Nova so they just asked me to move it quick b/c traffic.
I actually thought about this when I stopped, but looking at the sorry state of the building and grounds, I was 90% certain the place was abandoned. Seriously.
Rattled,
BRetty
