86 K20 Front Leaf Springs
viaminveniam1939
Dayton
Nick
Just replaced shocks and steering stabilizer. Observed, after I lowered the truck back to the ground, that the front leaf springs on my 86 k20 4x4 (former plow truck) are arched up slightly.
Is this proper or are they simply shot?
Thank U :)
WFO
Texas Panhandle
Thank U :)
That's normal.
viaminveniam1939
Dayton
Nick
After I wrote this I realized I hadn’t been that clear. When I think of leaf springs, I typically think of rear leaf springs having a “big smile.” My fronts tho, have a slight frown.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Factory front springs are shaped that way. Although, those look to me to be aftermarket replacement springs. The individual leaves will typically have a beveled or rounded edge. Those look squared up, but it could just be the photo.
Anyway, inverted arc is the factory shape. Your plow will make the arc more pronounced.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
For reference, these are the factory original springs I removed from my 1-1/4ton CUCV. Notice how flat the front springs are? That’s why they invert once loaded.
viaminveniam1939
Dayton
Nick
They are flat and those rear springs are beefier than mine. I suppose a cucv called for that tho? Different topic: How or will u or can u even address the speed limit rating of the cucv (65 or 75 is it)?
The Army stenciled the CUCV fender with a max speed limit, but AFAIK this is only a driver safety limit set by the Army. With proper tires they are safe at normal highway speeds.
Blazer body CUCVs are relatively comfortable at normal highway speeds, but the high GVW pickups have a lower axle ratio (4.56?) and a 3 speed automatic, so they turn a much higher rpm at 65-70 mph.
viaminveniam1939
Dayton
Nick
I didn’t this realize this!! Before I found my k20, I passed up on several low mile good condition CUCV’s out of fear / ignorance, that I would have to do some major swaps to not burn anything up.
Damn. Even your discarded parts are super clean, lol.
SquareRoot
The perfect combo for a nv4500 swap..uh huh yep
SquareRoot
Gears, OD or gasoline engine swap. That diesel be screaming at 3500 rpm.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
To be fair, I disassembled them and cleaned them up before I swapped them for the ORD customs.
::cue @idahovette ’s standard response:: lol
The rear springs made it ride like a buckboard. Didn’t come into its element until you had a yard of road base in the bed.
A 6.2 with 4.56 gears is a recipe for 60mph top speed. A gear swap or a gasser on some bigger tires will make a CUCV more freeway suitable.
nbrizjr
