Car Enthusiest
- Jul 26, 2014
- La
- Steve
- c20 scotsdale
- hopped up L31 waiting for a hot 400
Hello, ive been restoring a 78 c20 and have already purchased and have a few questions about purchasing my forged rotating assembley and what my engine may possibly put out
I have a 2 bold main 400, first im getting a forged 400 crank or maybe a slightly larger crank if it doesnt cause clearance issues 6" forged rods and most likely .20 over forged pistons, i probably will boost this one day but if i dont would want to know if hyperuetetnic pistons could handle this engine n/a i may rev to 7200
This is my engine build so far
Vortec sbc heads off a 93 z71 i will probably port the heads
valvetrain
8- Int Valves 1.94 X 4.91
Swirl-Polished
Hardened Tip Stainless Steel Valves
0.34375 in. Undercut Stems
Increased Flow
http://www.jegs.com/i/Edelbrock/350/9779/10002/-1
8- Exh Valves 1.55 X 4.93
Swirl-Polished
Increased Flow
http://www.jegs.com/i/Edelbrock/350/9773/10002/-1
Valvesprings
Outside Diameter: 1.265"
Inside Diameter: 0.880"
Coil Bind: 1.160"
Complete Kit: Includes Retainers And Locks
Springs Made of Highest Quality Spring Wire
Springs Precision Wound To Close Tolerances
Includes Superior Quality Steel Retainers
Includes 7 deg. Heat-Treated Valve Stem Locks
Retainers and Locks Black Oxide Coated
http://www.jegs.com/i/Edelbrock/350/5794/10002/-1
cam
Operating Range1500-6500 RPMDuration Advertised296° Intake/300° ExhaustDuration @ .050''234° Intake/238° ExhaustLift @ Valve.539'' Intake/.548'' ExhaustLift @ Cam.359'' Intake/.365'' ExhaustLobe Separation Angle112°Intake Centerline107°Intake Timing @ .050"Open 10° BTDC
Close 44° ABDCExhaust Timing @ .050"Open 56° BBDC
Close 2° ATDC
Intake Valve Lift (in.)0.539 Exhaust Valve Lift (in.)0.548 Int. Duration @ .050 in. (Deg)234 Exh. Duration @ .050 in. (Deg)238 Int. Duration Advertised (Deg)296 Exh. Duration Advertised (Deg)300 RPM Range3000-9000 Engine Make/SizeChevy Small Block (262-400) Lifter TypeHydraulic Roller UsageStreet/Performance
Both specs from my cam on the jegs ssite
http://www.jegs.com/i/Edelbrock/350/22015/10002/-1
Premium '50' Series Roller Rocker Arms
Small Block Chevy
1.5 Ratio
3/8" Stud
16/Pkg
Features:
4130 chrome moly trunion
Made from 2024 aluminum (stronger than 6061)
Bearings Made in USA
The latest advancement in aluminum rocker arm design
Lifetime warranty
CNC-machined, lightweight CAD design for quality & ratio accuracy
Additional clearance: Clears 1.625" O.D. valve spring
Rigidity to withstand aggressive spring pressures and high valve lifts
http://www.jegs.com/webapp/wcs/stor...002&langId=-1&productId=1250566&storeId=10001
I have a 700r4 built for 700hp ready to go in too
1800-2100 Stall Converter Included i probably will buy a 3800.. i need a flexplate too
Remanufactured Heavy Duty Pump Assembly
Heavy duty HIGH ENERGY Z pack clutch set
Heavy Duty Wide Band
New sun shell "Heavy Duty" THE BEAST
13 Vane Pump Rotor Kit
Hardened pump rings
New Sprag
Complete new bushing kit
Corvette Competition Servo
Master rebuild kit
Heavy Duty 5 Pinion Planetary
High volume filter
2 Stage Transgo Full Race Shift Kit
500 boost valve
Available in Lockup or Non Lockup ( PLEASE SPECIFY) or will be built Lockup
Up to 700 HP
i may run e85 on it or 91 im still undecided and pretty set on my rotating assembley options i said previosly the pistons will also be 9.5.1 most likely that is what i was recomended by 2 machinists i know let me know some of your opinions.
if i boost it will be nitrous exress or a d1sc procharger or weiland roots
i have a weiland speed warrior intake mani and a new 600 cfm edelbrock i am going to build up also and headman longtubes with a 3 inch collector.
im gunna buy a msd ignition kit
I just want to hear some of your guyss opinions on this and possibly what you would reccomend, thank you
valvetrain
Swirl-Polished
Increased Flow
Swirl-Polished
Increased Flow
Valvesprings
Coil Bind: 1.160"
cam
Close 2° ATDC
Small Block Chevy
1.5 Ratio
3/8" Stud
16/Pkg
Features:
Lifetime warranty
Hardened pump rings
New Sprag
Master rebuild kit
High volume filter
500 boost valve
Up to 700 HP
