5akman
- Jan 10, 2017
- CA
- Lance
- K20
I posted this last year about a 1894 K20 rebuild for use on the beach in AK hauling fish. That truck project is finished and running fine.
I now have 1980 K20 with wrecking yard BBC in it. I thought it was a 454 but block casting numbers show to be a 1970 396/402 truck motor with -950 heads. I'm not opposed to building the 396 but would need build specs for a low rpm torque monster engine for use again on the beach hauling fish.
I have some 236 peanut port heads with mild bowl work/porting and I read where they are good for this application. I'd like advice on piston and cam options for use with the PP heads and this particular use. There is not much out there for reference!
Other option is to sell the running 396 and either rebuild a SBC or buy a GM crate engine and do some cam mods. Is that 396 worth anything on the used market?
