Help!!! Removing House Paint???
86Apache
Banned
WV
Marvin
C10's ,K20
250 six, 350's
Dustless blasting??
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I've used Goof Off on old paint with good success.
Goof off does work great. For whatever reason, the can says do not use on large areas...
Definitely worth a go. Home Depot has it by the gallon.
Nathan
Kentucky
Nathan
Well guys I finally found something that works pretty good. Master Pro Automotive Paint Stripper at o'Reilly's. It's a time consuming process but worth it for the results. I started with the hood because it was already off the truck and easy to get to. Brush it on really thick because the house paint seemed to soak it up, then crack open a beer and watch your favorite TV show for 45minutes to an hour then go back and scrape it all off. Took about two applications to get the hood to bare metal but all depends on how thick the paint is. This is some nasty stuff and definitely recommend a well ventilated garage or do it outside. A mask is a must because the fumes are pretty strong, worse than paint, I'm sure those dust masks would work but I broke out the respirator. I would post pics if I could figure out how on this site. Best of luck to anyone going through the same problem definitely worth giving this stuff a try.
DanMcG
Central NY
k10 k10
It took the factory primer off too? thats something
Nathan
Kentucky
Nathan
Yup factory primer too.. the only thing it doesnt take off very well is body filler. For some reason previous owner skim coated some of the hood with body filler and the paint seems to stick on those parts a little better. But it took off the majority of it and got it to the point where its manageable to sand or hit it with a paint removing wheel to finish it up
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Posting pics is easy.
When ready, select "Upload File" at bottom right of post.
Select location,
select file to upload,
left click pic then left click open,
or double left click pic and it will upload
Easy peasy!!!!LOL
73454GMC
Greensburg, PA
Soda Blast it. And I don't mean one of those cheesy units from Harbor Freight. Check the web for a soda blaster in your area. They'll be able to strip your entire truck in a few hours. It might cost a couple hundred bucks or so but you'll save one hell of a lot on sand paper and stripper plus you won't have to deal with the aggravation of the job.
WHEELMAN
HICKORY TAVERN SC
BILL
454 v8
I had something like this.on a vehicle.i used a good brand rubbing compound
With a rag.lots of rags.and lots of rubbing.use it put it on heavy.so it will soak in to the paint.
I only had to do.doors and front fenders.it took part of a day.so if you go this route.to get that paint off.
You are looking at some time.if you sand.you going to ruin what ever is under.if you are going to
Go to mental.just pay a body shop.to sand the whole body down and spray prime the vehicle and then.if you want
You can have it painted.
Snoots
Roger
Jimmy Sierra
350 w/203
Body filler will soak up any stripper and cause your new paint to bubble.
You have to remove the old filler too.
I like MEK.
jlyon1006
