Removing Old Paint
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
That's funny. I actually bought my rusty c10 partly as a "learning platform" for a lot of body work and paint items that I wasn't willing to try on a chevelle I've been restoring.
This truck is only meant to go fast, ugly or pretty lol
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Sandpaper and elbow grease
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Heat gun? I just bought one and it says it'll strip paint.have not tried yet but was curious about it.
Vbb199
Salisbury NC
Vince
I took The tailgate off and did some wire wheel work to start, then a light coat of oil and a good wipe down to get the excess off.
thoughts ?
thatd be a badass patina scheme
waterpirate
delaware
v10
5.7 tbi
I would add that oven cleaner will take off the ******** and leave the real paint. would prolly give you a look you are wanting.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
thoughts ?
Its not for me... But please don't take offense, I'm of the opinion that it's your truck and your opinion is really all that should matter. The only reason I replied is you specifically asked for opinions, and no one has spoken up yet.
So the real question is, do you like it?
Vbb199
Salisbury NC
Vince
Well, I always welcome all opinions
The truck needs a good bit of metal work if I'm to restore it and make it all one color,
However, it's growing on me.
I walked out this AM and looked at it again with frost all over it lol
I like it.... I'll sit on it another day or so. I might try other things that these gents tried
I did use sandpaper and it wouldn't cut it without destroying the old.
Wire wheel messes up the cardinal red
I think they put an enamel paint on the truck.
Vbb199
Salisbury NC
Vince
With the sun beating down on it, I snapped a pic to show the contrast.
CalSgt
CA
Casey
Something to consider would be how much heat is the wire wheel putting into the panel and how much pressure you had to apply to get that look.
If you work a section and it stays cool to the touch you are good to go, but if it is getting warm/hot you run the risk of warping especially on the larger flatter panels.
How hard did you press when doing the tailgate? Tailgate is a heavy gauge body part with a bunch of structure to it, it's not likely to get damaged by wire wheeling. The big panels (especially the top of the cab) can be dented/damaged with much less force.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Hey Vince, what cha running for a motor...future plans motorwise.
Craig Nedrow
Washington State
Craig
K10, K20, C20
I've been a machinist 40 years, retired, today was my second day in a automotive machine shop, hope to build a couple quality motors, and do all the work on them, THAT's why I am interested in what you are/will run for an engine.
Idk if this project is done or not,but lacquer thinner will remove most repaints without hurting most factory paints. Take some lacquer thinner and check a spot in a door jamb or under the hood. You ever spray paint on something and everything starts bubbling up,that's usually lacquer thinner eating enamel.Use a bond spreader not a putty knife taking off the bubbled paint.
jlyon1006
