Help please! Hood wont open!
You didn't need to ask for it. He pretty much served it up on a platter. :rolleyes:
Yes he did. He didn't even care to give it up, likely since his gf had his balls in her purse.
What a major ****** douche bag. Good job guys.
The Hoe is looking good. Is that your same boat? It look different too. So how is the Hoe working out?
Thanks HR. Yeah she gets a hot wax wash every week. So far so good. Just hit 313K. It's fun to do stuff like replace headlight housings, door lock actuators, plugs and wires, simple stuff. I don't miss that fighting rust ******** one BIT. Also just installed a dash cam and looking into eventually adding a sub in the rear to compliment the factory Bose system. Came across some cheap replacement fog light housings on Amazon so they are on the way: :)
https://www.amazon.com/gp/product/B06ZYN1D69/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
The boat is the same. I just re-powered it with a new to me outboard motor over the winter and slapped those LED's on the front.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Holy cr@p! A working Force that's not on a Bayliner? You've got a unicorn there my friend.
Thanks! This thing is a beauty, got REAL lucky finding her at a dealer up in Reading, Pa. I paid $575 for it. It's a '97 40 HP 2 cylinder. Has power tilt, electric start. Spotless, 150 compression both cylinders. Runs beautiful. It didn't come with controls or ignition harness or prop so had to order a prop and used some old controls and a harness from the last motor. I run it on a 17.5' Tracker and it throws it up on plane no problem. Cruise at half throttle is 21 mph, full throttle tops out at 26.
Obullard74
