PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- Suburban k10, bonanza k10, c30 C&C, c10, gmc 1/2ton
- 350, 350, 350, 350, 350
Thanks for all the advice guys.
Here is what happened. I marked the housing and pinion nut with paint before removing the nut. While the nut was off, I noticed the pinion had some play in it. I thought that it was because the nut was off. I replaced the seal and tightened the nut back to the marks. The pinion was still loose. I tightened it a little further and it was still loose.
I am thinking that the bearing was worn which is why it started leaking. I never checked the pinion before taking the nut off. That was a mistake on my part. However I really never thought that it would be loose. This was an assumption on my part and we all know what that means. This is where the project stands as of now.
I just got my torque wrench though. I need to pick up a bearing separator now.
I am thinking about trying to tighten the pinion with the torque wrench just to see what the reading is when the pinion turns. I don't see how it could hurt. Maybe it just needs tightened. Yeah. Right. It can't be that easy.
I think 9 times out of 10 you wont be able to make the old crush sleeve work, if you're feeling ambitious you could just try installing a new crush sleeve and see what happens?
I don't blame you for not checking the pinion before you started taking **** apart! Ive done it many times, you get so into fixing what you see you forget to check for stuff that you don't see!
I know one of the other members had an axle issue I cant remember what was wrong exactly, but he snugged up the pinion nut and got it to work (not sure if it still is working or not) but sometimes you may get lucky and sometimes maybe not.
If you want to get really creative you can lift the axle up, pull the axle shafts out, and try getting your bearing preload to the correct spec, being its probably original maybe some of the bearings and shims have settled and you can crush the sleeve a tiny bit more to get the pinion tight
