Don5
- Oct 5, 2014
- West Virginia
- Don
- k15
So my Pinion seal is leaking on the dana 44. Since I am going through it I figure I might as well replace it as well. So I tear into it and replace the seal. I notice that there is some play in the pinion gear. Hmmm.
So my question is this- Is the pinion supposed to have some up and down play?
I am thinking that the bearing is worn and needs replaced. Everything on the front end points to it being original and nothing replaced inside. I figure since it is a 78 model it will probably need replaced. What do you guys think?
BTW- I have never set up a ring and pinion so this will be a learning experience for me. I checked the ring gear for any side to side movement and there is none. I thought it should move a little but it did not move any.
I am ready for a beer or two and I don't drink.. Someone can drink several for me......
