Help Identifying lift height
70SBUDGET
SAN DIEGO
RYAN
K20 CUSTOM
Picked up this beast a few months ago. As seen it is sitting on 33/12.5-16.5s.
I’m in the market for new tires and found a smoking deal on raptor takeoff 315/17s. Wondering if anyone can tell by the current stance the approximate lift on the truck?
nvrenuf
Mobile, Al.
Stock suspension measures 8.5” between the bottom of the frame and the top of the front axle tube.
Rumbledawg
the back 40
K30 crewcab
had a blazer with 33's and a 4" lift, looks exactly the same height as yours.
quite the gap between your roof and camper overhang. my camper sits about 3" above my roof
Redfish
Prairieville, LA
Andrew
V1500
My half-ton is sitting on a 2" lift and 33x12.50-15s if this helps you.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Are you always going to have the camper on it? Would be interesting to see the height with it unloaded.
This is mine with 315/75R16s and a 5" lift.
full
Craig 85
Nashville, TN
454/TH-400/NP205
Here's my last truck. I installed a 4" Tuff Country spring lift in front and a 4" rear block. The measurement from the upper body trim to the axle center lines is 32". Tires were 33x12.50x16.5".
Auburn, Washington
Assuming you have the rims for the 17s, 315-70-17 is virtually the same size as 33-12.50s. No issue if you’re happy with the fit now.
Yoginess11
