Ypsik10
- Jun 1, 2016
- Ypsilanti mi
- Chad
- K10
Sorry having trouble sending pictures again
Well, the hottest 350 used in the 1970 Corvette was rated at 370 hp @ 6000 RPM with a fairly big solid lifter cam and 780 cfm Holley carb. And that was still "SAE gross" hp back then, which is essentially today's "dyno shop" horsepower.I would say 325 (give or take) horsepower. The headers help, but the big gains are always gonna come from how well your heads flow combined with how effective your cam is in conjunction with your heads. With the aforementioned head work, plus your cam intake, headers, I would venture a guess of 400 horsepower. This is just me saying this, though. I'd like someone else to chime in.
Now maybe those number were artificially low for insurance reasons, but I still think an honest 400 hp would be hard to attain from a 350 with that Comp 268 cam, and even 9.5:1 compression. You'd have to build it to rev to >6000 RPM to make 400 hp. Or use modern heads, something like AFR 195s, but still use a bigger cam than the 268.
Looks like no threads are missing, so this may work in a low budget situation:
Run a bolt through a grade 8 flat washer to see if it will tighten at least 6 turns, and that the threads will hold 30-35 lb/ft torque. (Choose a bolt that will not bottom out.) If the casting doesn't bulge out, you're probably OK.
As for the used cam, if you don't know which lifters went on each lobe, then don't use it! Even so, I wouldn't use the cam and lifters if they came out of another block. Cams and lifters are cheap compared to tearing down an engine with a wiped cam lobe. I assume this not a roller cam, right?
Never did hear if the pistons are flat top or dished.[/QUOTE
Pistons are not flat top stock Pistons from a 74 350 2 bolt slightly dished with 4 valve reliefs machine shop said 64cc will not put my compression to high .. I'm weary and not sure if I would buy them .. Would that make them more likely to get a crack?? Can't find any other 461s .. Other than my machine shop down the road 600$ guide plates 3 angle valve job ungraded springs... I have a MASSIVELY junkyard neer me with tons of Chevy trucks I think they only charge 35$ a head for cast heads was thinking about maybe spending a whe day pulling some vortecs???
...was thinking about maybe spending a day pulling some vortecs???
