Heads up on 3" drop spindles
Rusty1
Washington
Rusty
GMC C10 SWB
Finished lowering my truck last week. I work 12 hour days so I just got around to completing the brakes today. I noticed the calipers were hard to install, thought it was just the new spindles. Got everthing put together and could not get the drivers side to bleed. After trying everything I could think of I noticed that the brake line was pinched.
Because of the higher mounting point of the caliper on the drop spindle the brake line was pinched by the upper ball joint location. I bent the hard line out of harms way and now all is well. I came real close to buying a new caliper thinking it was bad. The new spindles were from thesuspensionsource. So far so good. They were an easy install. Just a few screw ups by the installer. The truck drives straight before a front end alignment. I think I will have to do some trimming on the lower A arms to clear the factory 15" wheels.
Thanks for the info. :)
J Knight
Baytown TX
82 Chevy
350ci
You have to slightly bend the brakeline when installing any drop spindle because of the "clocking" of the caliper from the stock position.
X-cabsquarebody
Western NC
Billy
C10, C10 ,K30 , 3500
305 TPI, 454, 8.1
I used 2 1/2 drop spindles on my truck to be able to clear 15'' rims. I also had to bend the brake lines to keep the hoses out of harms way. The weird thing is the amount the spindles actually dropped the truck!
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i had to trim the lips off the lower ball joint around the ball joint after installing my 3'' drop spindals on my 85
static_86
Ontario
yep i had to do everything u said bent the brake line but i ended up grinding down the mounting surface where the caliper attaches to the spindle because mine were thick for some reason. my stock 15" rims cleared by not even 1/4 inch
SHILOW
HOUSTON
D
After installing 3" lowering spindles I had to grind on the lower control arms to keep the 15" stock wheels from rubbing on hard turns.
friscobob
Sutherlin Oregon
Bob
C 10
X-cabsquarebody, did 2 1/2 drop spindles lower your truck as much as shown in pic?
Bob
78silverado
