Headlight Piece
83kid
Massachusettes
Hi,
So on the headlight switch, where you pull it out to turn it off, the knob or whatever the piece is keeps popping right off whenever you pull too hard. How is this supposed to go on/be held on?
Thanks!
MadOgre
NA
NA
NA
NA
NA
its a force fit set up. the shaft of the switch is force fit into the knob. There is a little button on the switch behind the dash that releases the whole shaft and knob as one piece. A lot of guys don't know this and just pull really hard until the knob slides off the shaft when they need to remove the dash bezel. You can get away with doing that once or twice but do it to many times and you no longer have a force fit. Now the hole is bigger then the shaft. and you need to find a replacement shaft and knob.
83kid
Massachusettes
Ohhh, thanks!
I have some stuff to fin the ill the hole knob that ill put in, let harden a bit, and press it the shaft.
Wheres this lever to get this shaft out exactly? Tried to get it out today, couldnt feel a lever behind the switch.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
It's a little dome button on the bottom or side of the switch. Gotta reach from underneath the dash. You won't be able to see it while you're doing it. Also, you'll end up turning on your lights when pulling the knob out.
83kid
Massachusettes
So how do i not kill my battery?
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
After you depress the button, pull the knob out, more than likely you'll turn on your parking & headlamps. Then gently push it back in just far and hard enough to turn off the lights, but not engage the release button , then pull it back out.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
unhook the battery until you put the knob back in :shrug:
chengny
To get the shaft out of the switch, pull the knob all the way out to the H/L position then press the release button and remove the shaft.
Burban90
