- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
The ad230 and cs130 are 105amp alternators and they both have “soft” start and slow ramp up regulators. If your 10si or 12si doesn’t cause belt to chirp, there is no reason the cs130 and ad230 should start to do that tooIt's about 4 1/2 amps per-bulb. I'm sure a healthy OEM alternator can manage the 18 amps, most of these trucks are running either a 63 or 78 amp alternator.
Kind of a side discussion (which is fine with me), I don't like to see people go to high of amperage alternator. The CS130 I think is rated at 160 amps, and the AD I think is up there too. Both designed for a serpentine belt, the problem comes in when you try to spin that thing with a single V-belt, you get a low battery and that alternator will shread a single V-belt, it's just to much load. IMO, even an alternator around 80 amps is getting close to where dual V-belts would be ideal, certainly anything over 100AMPS really aught to be dual belted. This is one of the reasons we saw some rigs later on run V-belts for the air pump, A/C, Power steering, but a simple manually adjustable serpentine belt, which typically went over the water pump and alternator. It was to handle higher output alternators.
None of this is needed for an extra 9 amps. My square is single headlights, but I've got hella 550 fogs and use them a lot with the low beams. They also draw about 9 amps for the pair. The alternator handles them no problem even at idle with the heater rolling out defrost on high. I'm running a 4 year old ACDelco reman alternator, I believe it's a 78 amp.
If the 4hi mod used relays, disregard the next thing. If it doesn’t, be conscious about the voltage drop between battery and lights and the alternator relative to all that as well.
If you are comfortable with your alternator, keep it. Just at low RPM is what I’m thinking about
