Headers and trans crossmember question
WesN
Edmonton Alberta Canada
Wes
C1500
On my 81 shorty 2wd I install a set of Hooker Comp long tube headers from a 72 Monte Carlo/Chevelle. They fit nice and clear the mounts and frame nice BUT the pass side outlet lines up right in the middle of the trans crossmember. The drivers side is fine because the crossmember drops down to clear what was the old pellet cat converter and the outlet will clear over it. The headers are close to even with the frame so would be good on bagged units.
Now my question is has anybody used or come across a bolt in crossmember that the exhaust will clear? My other option was to get another like I have and cut the drop side off (drivers) and weld it to the stock one (pass side) so it will drop under the frame on both sides.
On mine (also using car headers), I used S-bend collector reducers and mildly restructured the crossmember on that side. I also ditched the diagonal brace.
78C10BigTen
pennsylvannia
C10 BIG TEN
I had the same problem on mine, i also ditched the 2 diaganol brackets that go to the top of the frame, partially due to going through 4 transmissions. But i had another set of headers from an old engine purchase that the collectors pointed down at more of an angle, i just used those and a sketchy looking adaptor.
I know that dual exhaust was a factory option, and have been told that there was a different W-shaped crossmember used with dual exhaust, but I've never actually seen one for a truck. I have seen performance crossmembers advertised for some older GM cars, but no listing for trucks.
Transdapt also sells several universal crossmember kits, but I'm not sure what would work for our trucks.
I also found this crossmember for 67-72 trucks. Maybe it can be adapted. http://www.classicperform.com/Store/1960_1972_Chevy_Truck/6372LDL.htm
This one is supposed to be universal. http://www.classicperform.com/Store/1960_1972_Chevy_Truck/CP90171.htm
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
With my long tube headers, had a shop bend exhaust piping to curve up and over the trans cross member on the passenger side. Its a tight fit, but it clears. My header flanges touch the pavement when the air is dumped from the air bags.
Smindustries
ATL-ish
Sierra Classic
0.0L
Two diagonal brackets? Does yours look like this:
78C10BigTen
pennsylvannia
C10 BIG TEN
Kinda but my "humps" that curve up are higher. Theres a pic of it somewhere in my media pages. I just tagged you in it
Looks like your crossmember overall is higher, even at the trans mount? One thing to note is you appear to have actual truck headers. The car headers don't hang as low. So it may just be how it looks in the photo?
And to the OP, the picture I posted showing the S-bends is on my C20 Burb. On my C10 that uses the crossmember like yours, I used the same type S-bends to run the exhaust ABOVE the crossmember, not below.
78C10BigTen
pennsylvannia
C10 BIG TEN
My headers do drop past the frame. Maybe they are truck headers. Im not sure. The ones i was gunna use came off a 90' k10 gmt 400 that had a 76' 350 frankensteined into it but they were too close to the floor and wouldnt go under the cross member. These on it now came with the 350 i blew up previously so im not sure what theyre actully for but they were alot better fit. To look straight at them from behind without pipes on them they point more twords the ground and not flat
Flowtech headers for our trucks have a slight downward angle to the collectors.
WesN
Wes
C1500
After weighing my options plus the fact I was in the Phoenix area I decided to go with the DirtyDingo crossmember. Drove out to Mesa and picked it up. Really nice guys to deal with and I’m not doing an ls swap but if I was I would take a serious look at their stuff.
seanhatesregister
