Header farts
hey mister
North Coast
Marty
Yep, ya guessed it.
A couple weeks ago, while tooling down the x-way, I heard the new header gasket give up. (Sound change)
I don't think the headers have been on more than a month, with maybe 300 miles on them.
Yea, I know...folks said there would be gasket issues or bolts constantly backing out.
I accept that, because the trade off for a happier motor and cooler bay is worth it.
I just have to find the right combination and I'm willing to tinker with it, to make that happen.
So, if ya "been there - done that" and you found the right combo, share it, please.
Thanks.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I’ve had good luck with Remflex graphite gaskets and the multilayer aluminum “dead soft” gaskets.
As far as bolts go, I’ve used transdapt header bolts and they seem to work fine. They have a reduced diameter head, but nothing special about them, other than likely the cheapest at Summit at the time.
Rustisbest
Just the facts
Athens, TN
Felpro steel core laminate gaskets and ARPs with the 5/16 head.
I go back and check em after a few heat cycles then once a week for a month or so and then let em go. Never had any issues.
I have a couple buddies that swear by the "Stage 8" brand locking header bolts
SquareRoot
Easy. Toss em in the trash and install these. You will wonder how you lived without em.
fast 99
Spokane, Washington
Above is an absolute, recheck recheck recheck.
Suggest applying a small bead of high temp silicone to both sides of the gasket, let it set up for 15-30 minutes, install. Just snug bolts up and come back the next day and tighten. Also, cheap headers usually do not have a thick enough flange. It will warp and gasket can blow out. If the flange is already warped it will never stay sealed in the long run, new headers.
nvrenuf
Mobile, Al.
The real lesson here is cheap headers (or expensive headers with thin flanges) suck. Thick flanges don't warp easily which means the gaskets are far less prone to leak. My headers have a 3/8" flange and only recommended high temp RTV, no leaks here.
fast 99
Spokane, Washington
I don't use gaskets on cast manifolds but never tried it on headers, interesting. Might try that in the future.
Yep, ya guessed it.
Thanks.
Remflex for sure. Doesn't really matter on the bolts, just make sure you get ones that you can get a socket on so you can torque them down properly. With the remflex, I have put them on, torqued to the remflex spec, go for a nice long drive, let them cool down and then retorque... done. Never had to touch them again and no leaks... ever.
2manysquares2care
