Has anyone relocated windshield wiper motor
sqhead
Mexico
Roller
custom k10
I’m looking to clean up my firewall. Has anyone found any kits or have any ideas on how to relocate the windshield wiper motor on a squarebody. Mines an 85 k10.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Instead of trying to redesign the wiper system, why not design and build a cover that will hide everything......
sqhead
Mexico
Roller
custom k10
this might be a chose between "wipers" and "clean firewall" kind of a situation....
That may be the route I have to take. I was just hoping to keep it all clean, but that is probably the route I will end up with.
Doppleganger
OH-MI: Just like it sounds
I saw someone online do a Japanese motor swap - much smaller and easier to cover. New enough I would bet there is a stock cover for it.
There will be plenty of fabbing and cobbing to do it and if you find one that fits, then controlling it will be the next circus.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I wasn't able to hide the wiper motor but I did replace it with a cleaner looking small unit that is 2 speed and variable delay. Also got rid of the cheesy mechanical washer pump and replaced it with an electric pump inside the washer fluid bottle.
ETA: If I would have taken the time to paint the bracketry and motor housing with the body color it would blend in well. Also I put the wiring in a cloth loom and it will tuck behind the brake booster brace nicely.
sqhead
Mexico
Roller
custom k10
That looks good. I like that idea. Mine is the big clumsy looking one. That looks much cleaner. Can I ask what brand that is?
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
What if you used one and the arms from a 67 72 c10. There mounted inside the firewall.
CalSgt
CA
Casey
This one is Newport Engineering, when I was researching there was one other company that had a far greater looking system and great factory looking switches but I forgot their name because they were significantly more expensive.
Here's how the switch ended up:
The company sells an adapter to mount their switch in the dash but I just altered the factory switch by cutting it up and adding a thin piece of steel to make it more stable.
I drilled out the slot where the old switch was and mounted in the new rotary knob, instead of sliding left and right it just turns clockwise.
From 12 o’clock to 4 is the delay adjustment range, then one click to 5 O'clock for slow, and another to 6 O'clock for fast.
sqhead
Mexico
Roller
custom k10
Thank you for all the good information. Very helpful
75BEASTK20
