hard to turn hubs?
6.2crew
yelm
josh
k30
Hello,
new here but have a little problem with my new crew cab. the hubs are very hard to turn. there are marks where someone has used a pliers or something to turn them. are they in need of maintenance or replacement?
please help
Georgeb
Wisconsin
George
K10 Burb Z71
Probably time to service the hubs and bearings including the axle bearings inside the spindles.
jetman
Minnie, AK
Don
Engaging manuals can be a two step process if they are a bit worn and/or dirty. Step one, place truck in neutral, hand rotate hubs to engage as far as possible. Step two, roll truck a few feet forward or reverse, hand rotate hubs to final engagement, the Outer Clutch Housing will smoothly into final engagement position. NEVER use pliers, hammer, other tools....
marks86
Latham, NY
Mark
12v Cummins
take the hubs apart and check it out, they are very simple to remove. I can go out on a limb and say the bearings should be regrease anyways
78silverado
