Guess The Tool
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Are you freaking kidding me!?
Well,... plus or minus 60 lb/ft. Fortunately there's no PTO on the engine. For that they recommend 700 lb/ft.
Snoots
Roger
Jimmy Sierra
350 w/203
What sort of engine is that?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Here's one I concocted today. It was made for one purpose, but could be used for another one as well.
Neither one is likely to be too challenging, but it won't hurt to give the thread a boost.
Manual engine starter... for real men. Flip that bitch over Luke...(haha a punchline for a Jean Tracy joke).
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That's the other purpose.
I made it to hold the flywheel in position while torqueing the damper because the torque on the damper bolt is 460 lb/ft and I didn't think sticking a screwdriver in the teeth would be good enough. But yes, it could be used to bar the engine over too.
Or to bust some annoying **** in the mouth too!!lol
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
It's for the 3208 CATs in my boat. The starter snout and pinion is from a Delco 40MT.
AFAIK the next, and biggest step up is a 50MT which will start a locomotive engine if two of them gang up on it.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
These are made by the L.S. Starrett tool company. The longer one is 12" long and the shorter one is 5". They have rubber tips but you can remove the tips to reveal sharp points. The handles are fixed to the base and don't move. The shafts can be turned by hand which slowly rotates the dials on the side. Interestingly, the smaller one rotates the chrome inner circle with the Starrett logo and the numbers remain stationary. The larger one rotates the numbers while the inner circle with the hash marks remains stationary.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Speed indicator/tachometer
Sent from my Moto Z (2) using Tapatalk
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Ding Ding, Winner Winner Chicken Dinner!
You're either a machinist or just good with google image search.
He's a smart cookie, I'll bet he simply just knew.
legopnuematic
MO
Spencer
No Google image search. I work at a regrind shop regrinding and making endmills, drills, reamers, and all kind of other things for primarily Boeing, and I just have an interest in machining and machine tools.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I had a revelation a couple of days ago about this thing so I thought I'd post it here.
It was kicking around in my father's tool box for decades and I never could figure it out. Then I stumbled across something on the internet and now I finally know what it is.
Anybody else have an idea?:
The front end has expanding jaws, and there is a drill bit hidden in the adjusting screw:
The drill bit has a hole through the web near the tip, which I still don't really understand the reason for, but I have a guess.
Before anybody says it's something like an anal speculum,... it's not. I just figured I'd get that out of the way.
This thing baffled me for years. Now it's your turn. But I won't make you wait that long for the answer.
73c20jim
Tombstone, AZ
Watch back remover.
SDJunkMan
Black Hills of South Dakota
Jeff
The hole is probably to pull a wire after you drill the hole, but I have no idea what the rest does.
fjordanasi
