Grinding Noise While Braking
9999
TX
This could go in the braking or driveline section, but not sure so putting it here.
82 K10 - Grinding or growling noise when stopping but mostly when almost to a complete stop and not while moving faster.
2 of us think it sounds like the front, 1 says the back.
Have recently replaced front rotors and brake pads. Bearings looked good and were timken. Previous owner had 4.10’s put in and not sure if just gears or swapped full axels. I have not pulled or worked on the rear brakes yet.
Replaced rear output shaft seal that was leaking recently and transfer case was somewhat low (topped it off). There is a slight driveline shake at highway speed when on the throttle (one second on one second off repetitive, will get driveshaft balanced). Not driven enough on the highway to tell if it was there before or after I pulled the rear drive shaft for swapping the seal. I’m not positive but think the sound I’m trying to locate was there before pulling the shaft, but not positive.
I put the front on jack stands and does not seem to be any lateral movement 12 and 6 o’clock. When spinning the wheels and applying the brakes all seems smooth. outboard sides of the rotors look perfect. Front locking hubs are working as normal when checked on the jack stands.
Anything else to check, thinking;
Jack up the back on stands and spin the wheels while applying the brakes and listen and feel for roughness.
Use camera or pull the front wheels and see how inboard rotors and pads look.
I don’t think it’s the unjoints, and will pull shaft and get balanced and new u joints but want to narrow down the noise first.
I was under there awhile back and motor mounts don’t seem to be bad, but I will check the fan shroud just for good measure (non factory 454 installed).
It does not sound like when rotors and pads get worn and it isn’t a squeal or high pitched.
Any thoughts or areas to look into?
9999
TX
Have put on miles since doing the front rotors and pads and didn’t have the noise for awhile.
fast 99
Spokane, Washington
Were rear return springs replaced, weak springs can cause noise.
9999
TX
I haven’t done the rears yet. I’ll put the rears on jack stand tonight and see if it pin points it to there. It sounds plausible.
9999
TX
Put the rear up and could tell anything obvious with sound. And drive around and no noise. Will wait for it to pop up again.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Very odd. Is it like a squeek squeek squeek squeek squeek squeek that changes with vehicle speed? I know you said grinding noise tho. Did you take drums off to see what it looked like?
9999
TX
It’s a lower groan or grind, and usually just at the end of a stop, like at a stop sign.
Almost like when there is more weight transfer.
It doesn’t go or change with speed or acceleration.
squaredeal91
Greg bush
1991 SB
I've had rear brakes sound like that. Just grind squeeky gravely. And one time I had a brake spring pop off and make noise.
9999
TX
Oddly enough, it’s mostly gone away.
I had someone ride in the bed to see if the sound was coming from the front or rear.
With the 4:10 gears and our driveway, I don’t ever think I brake much in reverse. It’s possible it self adjusted. I’ll see if it resurfaces or when I get a chance I’ll pull the back drums, but for now seems good.
85 Squarebody76
Missouri
Bob
GMC C1500
Sounds like the carrier bearing rubber cushion in the drive shaft squeaking
350 w/203
Don't go anywhere you have to stop or use the brakes.
9999
TX
The carrier bearing would only be on a 2 piece driveshaft right?
The truck has a 1 piece.
nbrizjr
