got a square body!!!!!!!! s10
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I did the cable back up on the pass door I figured some one would be less likely to look on the pass side for a back up.
Swims350
Logan WV
none
I need to find me a visor for this one, the outside cab mounted ones
Swims350
Logan WV
none
wow that's high I found some kinda far off on CL asked if they'd ship.
i think summit has some new ones for $140
Problem is used ones are scarce. At least up here. I had to pay $150 for mine and drive about 100 miles on top of that.
Swims350
Logan WV
none
summit has them new for $120 so that's not bad.
LOL funny thing is most I seen on CL were closer to PA
Stewzer55
Ohio
Stew
R30
Those Keystones look good on the first gen S10s.
Swims350
Logan WV
none
yea come to find out the fronts are 14's. summit doesn't even list keystone 14's now.
The reg. ones are more then cragar ss's now $190 each compared to around $170 on the ss cragars.
I mounted up 2 14's on them american racing rims today. May end up using the keystones up front, and then my old man's 2 cragars he's taking off his truck. They are 15x7 reversed offset.
Swims350
Logan WV
none
got some window guide clips and a new ignition lock cylinder for her today.
thanks to kleedus for the part no. on the guides.
Swims350
Logan WV
none
well this thing just hit a road block, somebody put a 4wd rear end under it, so even reg. wheels stick out now I have to find a 2wd rear or run fender flares.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I have a good 3.73 2 wheel drive rear but we are a long ways apart
Swims350
Logan WV
none
yea no doubt and I'd love to have 3.73 setup I was hoping for 3.42's are simialr.
local yard wants 250 but they have a 94 and 97 but I hear they all work.
Swims350
Logan WV
none
I think after all these issues I'm gonna do a reverse swap, put the 4.3 from the dime into my 88 k1500 so it can be on the road again then build the living daylights out of this dime. a 350, roller cam and all maybe 383, full shaved kit done right and full air ride done right, paint, whels tires, brakes steering all new.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
you will probably hate a 4.3 in a 1500
go for a newer s10 rear with disc brakes and a posi
Swims350
Logan WV
none
too much money. they want 400 for one that's newer and the older ones are 250 but I can get my choice of gears from 3.08's to 4.10's
and yes I probably would hate it in a fullsize but if it's cheap on gas that'd be good and also i wouldn't lose much if I just sold it.
kobedemello
