- Apr 11, 2017
- kansas
- Rick
- c20
Compression test,disable ignition by pulling the coil hot lead at the cap. Pull your plugs crank at WOT until your gauge quits climbing write down results. That's dry, Put a little oil in the cylinders 1 at a time and repeat your test,that's wet. A wet test will generally help determine if it is a ring problem.
