Gauge swap.
73c20jim
Tombstone, AZ
I was using brass. Using steel is a good idea.
mrburitto
Casa Grande, AZ
Cody
K20 Cheyenne Camper Special, C30 Crew Cab Dualy
  • Gas gauge accurate when stopped, but bounces while driving. Probably loos connection somewhere. Old one worked fine.
There is a pulsation dampener (a resistor actually) that bridges the two opposing coils. It's function is to control the rate of movement of the ray (needle) when the sender is generating large fluctuations in a short period of time - like going around a corner fast or slamming the brakes on. If the coil is open, or the entire ceramic plate - on which the coil is mounted - is missing, the gauge will bounce around violently.
If you still have your original gas gauge, you might want to swap out that dampening resistor.
Awesome you just solved my problem too!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Well crap, now I have another reason to pull the dash and replace a couple burned out bulbs!! Is this resister available from a vendor or do I need to find a good used one?
73c20jim
Tombstone, AZ
GAUGE SWAP UPDATE.
VOLTMETER
Reads 13v when ignition is on.
Reads 16v when motor is running.
Shop voltmeter shows about 13v when motor is running.
TEMPERATURE GAUGE.
Need to install correct sending unit.
Currently reads in OVERHEAT range when car is started.
OIL PRESSURE GAUGE.
New oil pressure sending unit for electrical gauge installed.
Reads 0 PSI at all times.
FUEL GAUGE
At first showed correct level and steady but bounced around while driving. Swapped resister thingy from old gauge that worked fine. Reads 0. Swapped in old gauge. Reads 0.
Working on these for three days now. Getting really frustrated. Really really frustrated.
Shouldn't the temp gauge show low even if sender is wrong?
Any help on any of these gauges will be greatly appreciated.
73c20jim
Tombstone, AZ
bump for help
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The only thing I can offer on the fuel gauge is ours had issues with bad contact between the spring clips and the circuit board. I think it was eventually soldered, but by pushing on the dashboard / cluster you could get a reading out of it. Sounds to me like you've got grounding issues or some other contact problem.
I agree, I think it's a connection problem like dirty spring clips.
83SCLB
