Gas tank installation help please
ivangf
Mexico
Roberto
Hello, i am new in the forum, i really like it, it is very nice.
I had to replace the driver side fuel sending unit. Now i am trying to install the tank back but it is very hard to connect the sending unit hoses :( cause there is no room for it.
Can somebody share a procedure to connect the sending unit hoses and install the tank without removing the bed?
Thank you for your support.
I leave my hoses long and attached at the tank with clamps,with a second set of clamps loosely in place I pushup the tank,fish my hoses over,shorten as needed tighten my clamps with a 6 in 1 screwdriver with the tip removed, so its a nut driver. Of course you use new hose it is much more pliable and you can get the length you need.
ivangf
Mexico
Roberto
Hello Ricko, that is a good idea thank you very much, i will try it!
RanchWelder
Earth
Blazer
355ci
It's tough to drop the tank and fix the lines without help and a way to jack the tank up at the same time.
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria.
As mentioned above longer fuel hose and a second set of hands.
I can do them by myself,no jack if they are empty. If you are using new tanks new straps new brackets leave the straps just barely snug,push the forward end of the tank up start 1 bracket bolt use it as a pivot,push the other end up start a bolt get all bracket bolts in place then tighten the straps
geolee
illinois
george
I used a motorcycle jack it makes it a lot easier
Camar068
10 yrs Air Force
good reason to get one....use it for trans/transfer case as well. OI....found adapters to go on a normal hydraulic jack for a trans. Game changer for me...and cheaper.
wkeithh
