Gas tank installation help please
ivangf
Mexico
Roberto
Hello, i am new in the forum, i really like it, it is very nice.
I had to replace the driver side fuel sending unit. Now i am trying to install the tank back but it is very hard to connect the sending unit hoses :( cause there is no room for it.
Can somebody share a procedure to connect the sending unit hoses and install the tank without removing the bed?
Thank you for your support.
I leave my hoses long and attached at the tank with clamps,with a second set of clamps loosely in place I pushup the tank,fish my hoses over,shorten as needed tighten my clamps with a 6 in 1 screwdriver with the tip removed, so its a nut driver. Of course you use new hose it is much more pliable and you can get the length you need.
ivangf
Mexico
Roberto
Hello Ricko, that is a good idea thank you very much, i will try it!
RanchWelder
Earth
Blazer
355ci
It's tough to drop the tank and fix the lines without help and a way to jack the tank up at the same time.
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria.
As mentioned above longer fuel hose and a second set of hands.
I can do them by myself,no jack if they are empty. If you are using new tanks new straps new brackets leave the straps just barely snug,push the forward end of the tank up start 1 bracket bolt use it as a pivot,push the other end up start a bolt get all bracket bolts in place then tighten the straps
geolee
illinois
george
I used a motorcycle jack it makes it a lot easier
Camar068
10 yrs Air Force
good reason to get one....use it for trans/transfer case as well. OI....found adapters to go on a normal hydraulic jack for a trans. Game changer for me...and cheaper.
geolee
illinois
george
Idk how well motorcycle jack would work on a lifted truck though. My truck sits pretty low so works perfect. Probably doing a transmission soon so maybe use it for that also. I lower everything lol my motorcycle is to low for the motorcycle jack
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
I used a transmission jack, you could do like ricko1966 said though. I left my hoses long enough from the tank on the ground and coiled when it went up.
DonN
Rio Rancho New Mexico
Don
I install the fuel lines on the tank first then feed them over the frame. The sending unit wire should be long enough to connect it as the tank is going up. Once you have the tank bolted to the frame connect the ground and hook up the fuel lines.
Long Rider
La Grande Oregon
I just installed a new tank, drivers' side, on mine. The new gas lines are a lot thinner than the original and looked like it may rub on the frame so I took a short chunk of garden hose and slipped over the new line, then connected the new gas line as suggested by Ricko. I have a motorcycle jack so I used that and found it VERY helpful. Welcome aboard
tabtabscroll
