SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
Fusible links are not fuses . . . they are current limiters intended to protect relatively fat wires that carry power to distant distribution points, usually fuse blocks where the power splits out to various appliances and sundry tasks around the vehicle. Fusible links are simply pieces of ordinary copper wire sheathed in an insulation that stands up to molten copper within while producing a minimum of low toxicity smoke. These insulations were developed for the electric locomotive industry where humans shared close proximity with at-risk wires carrying a LOT of current. The fusible link is sized at four wire-gauges smaller than the protected feeder. I.e. a 10AWG feeder should get a 14AWG fusible link at the BATTERY end of the feeder. In some cases where the feeder supplies a single load, no additional fusing is necessary for protection of the wires. But it may well be that a fuse-block at the downstream end of the feeder will carry fuses appropriate to the load of each circuit.
Fusible links are VERY slow acting compared with fueses as you might guess from their construction. They are NOT interchangeable. Most of the explanations on the 'net are simplistic and miss the point for incorporation of SLOW fuses in a power distribution system. Worked in aircraft for the last 50 years and while we don't use fusible link wire, we DO use very slow, robust current limiters that kinda look like a fuse . . . but they're not.
You will note that fusible links are 'rated' by AWG wire size, not AMPs like a fuse.
THANK YOU for posting this. I've been too lazy to say what you did but you're exactly right. Everybody wants to go with a fuse but they don't know why other than it's easier for them. Fuses and fusible links serve different purposes. If the OEMs thought fuses would suffice, they would have used them.
Rolls of different size fusible link is available at Napa.
Another point...you should NEVER fuse or limit the charging cable coming off the alternator. Like an uneducated dumbass, I put a 150amp maxifuse on mine and quickly burned it up. Don't do it. Just make sure the cable can support the amp rating of the alternator.
FWIW, I'm not an electrical engineer but I play one at work.
