Noremak
- Aug 11, 2019
- Lancaster, Ohio
- Kameron
- K10
I have a 79 k10 with a 350 small block. I bought a new mechanical fuel pump, it has three ports, Inlet outlet and the return (I think).Currently my return is plugged. I’ve been having problems with flooding and I’m thinking my fuel pressure is too high, i have a 600cfm edelbrock carb. I bought a holly fuel pump regulator with inlet and two outlets, no bypass. My question is, can I just add this regulator before the carb or will I need to also run a return line from the pump? I’m a bit hesitant to just add it and tune down the fuel pressure, all that pressure has to go somewhere right? I don’t want to blow a line or damage my fuel pump. I appreciate the help!
