StickyLifter
- May 28, 2022
- N/A
- Screw You Homophobes
- N/A
- N/A
- N/A
My truck has a 350 with a mechanical fuel pump and a quadrajet carb. It runs good, and starts good except for the first time I start it for the day. It takes some cranking before it starts the first time. Not a ton, maybe 15 seconds. I press the gas pedal down once and have confirmed the choke is closed. I'm wondering if the check valve in the fuel pump might be bad. Does this seem plausible?
