Fuel gauge
Pfonzi
Hilton Head
Pete
Silverado c10
hello I replaced my sending unit and float and my fuel gauge still won’t work.
Does the printed circuit control the fuel gauge?
Thanks for your help
Dmack
Central OR
Dave
Where is the needle pointing? 3 o'clock is an open circuit (like a broken wire or connection) and 9 o'clock is a grounded circuit.
John Hamilton
Washington State
V35
My fuel gauge is registering very high, the tank is empty the gauge says I have 1/4 tank. can you pull the needle out and reset it? thank you in advance.
Kim Burke
Northern IN
Kim
C1500
You probably have a sending unit malfunction. An 89 V35 unit will be $$$.
Dmack
Central OR
Dave
No, it won't work. You have an open circuit, so it's a broken wire, bad sender, etc. If you can get to it, you can pull the sending unit wire and put an ohm meter between the pin on the sender and ground. If it shows between 0-90 ohms, the sender is working and you have a wiring problem. If it shows open, you have a sender problem.
76Bluec10
