Fuel gauge to tachometer, clock to fuel gauge
chris3353
idaho
chris
v2500
hello,
Has anyone used the summit retro gauges to replace their square body gauges? I am looking at replacing my large fuel gauge with the tachometer and the small clock with a small fuel gauge. They appear to mount the same on both, just curious how they look after installed. Will be going in a 84 high sierra c10
Thanks
Alex
Alex,,
I also used the LMC kit,, It was better than expected, very pleased with the quality and the kit was 100% complete. It has been in for a few years and works perfect. I would recommend it over anything else if OEM look is important.
Also,, No cutting up any factory stuff.
84_c10_GMC
Alex
Alex,,
How is it getting its power and signal if not running wires to it? Does it replace the sheet on the back? And put wire into the plug? Or did you replace the entire cluster?
Soundmound
North Central Washington
Dave
Scottsdale
Alex,,
Did the same and agree. One button complete solution for OE fit and finish.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
I have a '74 cluster with a factory tach in my '75, and the tach does not use any wires from the large multi-pin connector. The tach harness is a separate three wire plug, and only has power, ground and signal from distributor. I'd have to take a close look to see if the illumination bulbs are in a different spot, but they work the same as non-tach cluster.
nbrizjr
