Fuel gauge moves around while driving
hatzie
k20
Between the nuts and the resistor. You're trying to make better contact with the resistor.
You can also lightly use a pink pencil eraser to clean off any corrosion without damaging the resistor.
Do all the instrument cluster lamps and other gauges work normally?
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Yes, all gauges work. Just have the movement in fuel gauge. Do not know yet if there is a resistor on the original gauge. Have not had it out to find out yet, but intend to soon.
Carb'ed Vortec 350
I noticed mine yesterday would move, but it was around a 1/4 tank. After I filled it, no movement, steady at full. Come to think of it, it only moves when it's less full
fast 99
Spokane, Washington
Have several loose gauges. Quick ohm check [not isolated] mostly confirms the Hatzie post.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Just found these. Would either work?
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
My guage moves while driving but it is obviously related to the fuel moving in the tank(moving the bob) because of inclines or bumps on the road etc.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Old guages.
zapattack
