Dazed
- Oct 29, 2011
- Portland, OR
- Chris
- 1961 (sitting on a 79 K20 4x4 frame)
- Apache 10
So back in spring I was out enjoying/abusing my truck in a muddy stump field and came down hard on the right front tire. I expected the bent parts, was annoyed by the power steering pump pissing fluid and not financially able to fix either at the time. Parked it and started saving my pennies. Jump to now, have new parts, go to move it into the shop and the front is absolutly siezed! A little investigating also revealed that the front brake resivor is bone dry. So first thought, 4wd and unstick it, will push the front tires about a foot and throw bark dust 60 feet behind. Second thought, fix it where it sits, but what could I be getting into here? Brakes and bearings I'm expecting but beyond that? Worth noting that it is on soft ground and I'm not at all comfortable with laying under a 7,000 lbs truck on jack stands in soft mud!
