Front shock bolt torque
Almcphee
Oshawa
Al
V6
Im sure it’s here somewhere, but I’m looking for top and bottom bolt torque values?
I don’t seem to have luck with”search”.......lol
Hope everyone is awesome !!!
Turbo4whl
Downingtown, PA
Wayne
Engines and transmissions, book specs are best. For other general fasteners a torque chart is very handy. This chart is listed in Ft/Lbs. Most automotive fasteners are either grade 5 or grade 8.
Almcphee
Oshawa
Al
V6
I have grade 8 bolts for the bottom , and the top bolts seem to be grade 5 ......but there is a recommended torque for the application and I can’t even find it on the Monroe site .
Turbo4whl
Downingtown, PA
Wayne
This is when a chart is needed. What size are the lower bolts, 1/2"? 110 ft/lbs. Every old GM repair manual had a torque chart in the back.
Dysco
Wisconsin
1/2" x 3 1/2 on top and bottom.
Torque until your lock washers are flat, plus a smidge more.
chengny
Front Suspension Bolt Torque - Nm (FT. LBS.)
QBuff02
Central IL
Quincy
run them bitches down and give em a couple, possibly 3-4 ugga duggas with your freedom air pistol and call it good. or reference the above chart for proper specs.
TubeTruck
East TN
Denis
Suburban K10
LQ9
Impact tight. Use locknuts for the just in case.
chengny
Per request, cleaned up front suspension specs:
And rear specs:
GorillaHumper
