dvdswan
- Mar 11, 2014
- Port Orchard, WA
- Dave
- K10
Welcome to the site.
You keep amazing me with your knowledge!Thats a 70's frame. 81+ frames have the horns cut at an angle.
My 85's frame horns
You must be registered for see images attachYou must be registered for see images attach
Unless I am mistaken, isn't the actual frame manufacturing date stamped on the passenger side frame rail just ahead of the fuel tank (on the outside)? I know mine is...
The factory front springs do curve downward. Upward would indicate a lift spring. Also are you sure the springs are 3" wide? Chevy springs are 2.5" wide, later Ford springs are 3" wide. If you measured the spacing of the bracket where the spring mounts it would be 3" because of the bushing.
andfrom northern IL
